I captured streaming media using Net Transport.
1) What format is the file? (It saves the file without a suffix).
2) How can I make a DVD out of the captured file?
I forgot to add that when I rename the file into a *.wmv file, the properties show that the video codec is Windows Media Video 9
and the audio shows Windows Media Audio 9.1 10 kbps, 16KHz, mono 1-pass CBR. -
Is it playable after you rename it? If it is, then it must be wmv format. Look in the AUTHOR section on how to make DVD's.
Google is your Friend
Media Format in TV Broadcasting
By altavistasf in forum Newbie / General discussionsReplies: 7Last Post: 13th May 2010, 17:31 -
i captured a video from reciever in .mpg format, [ a conversion problem] !!
By aSem-1 in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 17:22 -
Captured S-VHS format
By Rinsin in forum Capturing and VCRReplies: 24Last Post: 28th May 2009, 13:05 -
Capture aborts when media format changes
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 22nd May 2008, 18:09 -
Ok, captured my video as AVI format
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 00:37
