i have 1 file avi format converted to mpeg using tmpgenc plus ... problem that i have is i wanna shrink this mpeg file a minimum as can. So i can fit 2 or more mpeg file converted from avi to 1 cd. any suggestion ? sorry.. my english is poor.![]()
Lower the bitrate. (look in the Encode Mode box, settings button).
Cheers, Jim
My DVDLab Guides -
Try using avi2mpeg2 (aka bbmpeg)
It will accept avi files packed into non proprietry codecs .
Hit add , find avi , hit start encoding , hit settings , go to general settings .
You should find a box for mpeg , and down below is an mquant value , 4 is default , run it for a minute in the encode process .
After 2 or 3 minutes you'll get an idea as to the final output of the video file size , not including the audio .
If it appears to big you can change the mquant value to a higher setting , but I dont recommend going past 5 or the video suffers . -
An m1v is the video only portion for VCD.
If you select "System (Video+Audio)" it will create the proper mpg for you to burn to VCD.
Select the same avi as your audio source.Cheers, Jim
My DVDLab Guides
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 12:02 -
Want to resize an avi
By janlafata in forum Video ConversionReplies: 2Last Post: 18th Aug 2009, 00:06 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Crop/resize mpeg-2 to remove pop-up ad
By CaZeek in forum EditingReplies: 9Last Post: 8th Sep 2008, 23:43 -
how to make sure that your output format for autogk is either, avi, mpeg..
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 07:00
