Answer the topic thanks in advance!!
Is there any authoring apps that only allows you to do single layer DVD?
/Mats -
well with tmpg dvd author audio comes out of sync and nerovision gets errors.
Originally Posted by Bloody Sasuke
/Mats -
Author your DVD to a folder on your computer and check the a/v sync, burning probably is not the source of your problem as mentioned.
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 08:36 -
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
dual layer authoring
By miniboss91 in forum Authoring (DVD)Replies: 2Last Post: 20th May 2010, 02:37 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
