Hi,
Is there such a converter that can convert a VOB to VOB, just changing some stuff... like the FPS, Aspect Ratio and other stuff like that, whilst keeping it a VOB rather than converting it to an AVI. Any help would be greatly appreciated.
Regards,
diE
LiVe iS juSt EvIl SpElLed BAcKwArDS!
You are talking about format conversion and aspect ratio conversion. What's in the vob ? If it is movie only, demux, use dgpulldown on the movie file to change framerate (depending on what you need to change) and restream to change AR flags. However, if you are changing format between NTSC and PAL, changing framerate isn't enough - the resolutions are also different, and this will require a reencode in most cases.
Read my blog here.
Hi,
Yes, I do not mind a complete conversion as long as the result is a VOB file. Is it possible?
Regards,
diELiVe iS juSt EvIl SpElLed BAcKwArDS! -
What do you want to do? A VOB file is just a Video OBject file. It contains the multiplexed streams plus navigational information for the DVD. If you mess with the information in the VOB file too much, I'm afraid that you'll just end up with an unreadable file.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Hi,
I want to convert the VOB file, which is a video file from a DVD, and I just want to convert it to another VOB file just changing some things... like FPS and aspect ratio and resolution etc... basically from PAL to NTSC. If I can just convert all VOB's converting each from PAL to NTSC, I can enter them all in DVD-Lab Pro and re-make the whole navigation of the DVD.
Regards,
Sorry, but you can't do a standards conversion like that. Like gunslinger said, the two formats are different framerates and different resolutions. Just changing the A/R of the movie won't actually resize it.
Nice try, 'tho. It means that you're trying to think "outside of the box". Well, get back in here, and do it the "hard" way - just like the rest of us!ICBM target coordinates:
Hi,
LoL.. so what is the best way to do this and keeping the menu's?
Regards,
Input the video to your encoder, and resize the video to the proper size (720x576 for PAL, or 720x480 for NTSC). The video will be encoded at the improper framerate, but the chroma/luma information will be correct. You need to slow PAL down to 24fps, or speed up NTSC to 25fps. You also have to change the speed on your audio, or you'll have sync problems.
A menu is just another video file.
Then reauthor your film.ICBM target coordinates:
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Best way to convert NTSC .VOB --> PAL .VOB
By macuser1960 in forum ffmpegX general discussionReplies: 1Last Post: 9th Mar 2008, 16:43 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 05:44
