I tried to convert an avi file to dvd using winavi to dvd, the process stopped on 99%. I now have four vob files and 1 file with the extension .nav. I'm guessing this file would have been the last to be created. The vob files play on their own using nero showtime but only one at a time. I want the movie to play on my standalone so do i have to somehow repair the .nav file before i burn to dvd. Any help would be much appreciated.
Peace.
EDIT: The fourth vob fille only has partial sound at the beginning.
“He who makes a beast of himself gets rid of the pain of being a man.”
I would start again. First, I would use DivxFix or virtualdub to scan for bad frames. Generally, if a process stops short of the end it is because of corruption or bad data in the file. Once you have a clean avi, try encoding it again.
Read my blog here.
I also tried the file with nero,
Here is part of the log file.
[15:58:16] NeroVision Registry Keys:
[15:58:16] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
[15:58:34] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[15:58:42] GCHW Node added: Microsoft Kernel Wave Audio Mixer
[15:58:49] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[15:59:04] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[15:59:19] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[15:59:34] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[15:59:49] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:00:04] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:00:19] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:00:34] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:00:49] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:01:04] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:01:19] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:01:34] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:01:42] GCHW Node removed: Microsoft Kernel Wave Audio Mixer
[16:01:49] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[16:02:04] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
What does this suggest to you? I think the avi must be corrupt so i will try divxfix. -
Problem solved , i used vso copydivx todvd.
Thanks folks.“He who makes a beast of himself gets rid of the pain of being a man.”
Winavi Stuck while converting Rmvb to avi.
By godbowen in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2008, 11:02 -
DVD Stuck
By tvlreject in forum DVD & Blu-ray WritersReplies: 15Last Post: 2nd Dec 2007, 21:39 -
I'm stuck.... can't get *.mpg authored to DVD
By la7oea in forum Authoring (DVD)Replies: 2Last Post: 17th Oct 2007, 14:17 -
WinAVI Video Converter 8.1 (DVD gets stuck while playing on home DVD)
By Zuzuu in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2007, 13:37
