I am using textsub to hardcode subs to my movies. The only problem is in virtualdub when I try to load idx/sub files it does not load, but srt files load no probs. I tried to convert subs to srt which takes too long because it takes the entire words and not just alphabets. If you know what I mean. Please help.
thanks
Results 1 to 9 of 9
Yes, textsub is (surprise!) for text based subs. Sub/idx isn't text based. But IIRC there's a sub/idx VirtualDub filter in the vobsub distribution. But you're actually better off with text subs, as you can change font, placement & cetera - sub/idx is "made of pictures" which you can't control as much.
/Mats -
Convert sub/idx to .srt or .ssa, use textsub.
Like I said, sub/idx subs can't be customized to your liking as text based subs can. They are just images that gets overlaid. Text based subs, the overlay image is created "in real time" by the filter according to your settings.
/Mats -
Is there a converter without entering each word in that case? Or am I doomed?
thanks -
Use SubRip (Baldrick's written a mini guide)
You don't have to enter each word - but you have to enter each character once to make the app learn what "squiggly" represents what character.
First few sentences, it seems like you have to enter each and every characrter yourself, but pretty soon the app has learned to read by itself.
As every sub/idx or DVD uses its own typeface, font size & cetera, you basically have to start from scratch for each new DVD / sub you convert to text. But you can save the character matrix for later use - useful for 2 part subs or 2 disc DVDs - you just load the character matrix and off you go for the 2nd part.
/Mats -
You're right that you can't change the font of the idx/sub type image files, but you can change the placement, size and color. Unless you get a really crappy font, that's usually enough. I don't know why Mrsash is having trouble with them. I've used them maybe 100 times with no missing subs or problems of any kind. Doing it through AviSynth, loading the VSFilter and using the VobSub command. Although in principle I don't approve of burning subs into an AVI, and certainly not into DVDs, my first DVD/MPEG-4 player didn't support external subs for AVI, and I didn't feel I had a choice.
I usually dont hardcode subs either, but when its a asain movie where I dont know the language or other non english language I hardcode it as I have to switch them on anyway. Also I Author them in Tmpgauthor and it does not take sub files so I am doomed to encode it.Originally Posted by manono
mats.hogberg: thanks for you suugesstion. I did try subrsync already before posting. The problem was it read antire words and not just single letters so was here for hour and a half entering words, beacuse there are many word combinations than individual letters but will give subrip a try as well.
thanks
TextSub horror!
By YiuKorochko in forum SubtitleReplies: 2Last Post: 1st Aug 2011, 16:38 -
textsub incompatible with avisynth 2.5?
By icieling in forum DVD RippingReplies: 1Last Post: 1st Aug 2011, 15:56 -
Font problem with TextSub 2.23
By Keeyu in forum EditingReplies: 0Last Post: 8th Jan 2011, 20:42 -
TextSub in Avisynth.
By Sarlula in forum SubtitleReplies: 3Last Post: 18th Dec 2009, 18:24 -
Cn't get the textsub / subtext in VirualDubMOD
By download in forum SubtitleReplies: 6Last Post: 18th Jun 2007, 19:22
