Thinking of getting a Lacie D2 external SATA drive for my laptop (will need a external SATA adapter PCMCIA/Card bus card, see below also)
It runs at 10000rpm !!! Fastest external hard drive I've seen with an access time of 6ms
74Gb is small but still enough to get quite a bit of footage on. Combine this with my internal laptop 60Gb 7K60 7200rpm Hitachi hard drive.
What do you think?
http://www.savastore.com/productinfo/product.aspx?catalog_name=Savastore&product_id=10...EEA9BB61B2B020
SATA adapter - plugs into standard laptop PCMCIA expansion
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=107701
Seems a little expensive.
However, 10,000 RPM drives are rather extremely fast. I wonder if its just a rebagged western digital as that is also 10,000 RPM and 74GB. -
Those fast drives are really only good as an OS drive or something else that can really use the faster access speeds, otherwise it's a waste of your money. You'd be better off spending that money toward a larger 7200rpm external hard drive, but you're on the right track with the SATA interface.
FB-DIMM are the real cause of global warming
Does LaCinema Mini HD Connect support Lacie Rikiki 1 Tb external drive ?
By centrino3 in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2010, 11:09 -
What is the best use for a 10K rpm scsi hard drive?
By Haopengyou in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2010, 10:00 -
can't encrypt dvd from external Lacie
By jsteve in forum ffmpegX general discussionReplies: 12Last Post: 30th Jan 2010, 10:12 -
LACIE external
By eddie100 in forum ComputerReplies: 2Last Post: 28th Nov 2008, 13:53 -
ide dvd burner and sata harddrive - how do i configure?
By mshuang in forum DVD & Blu-ray WritersReplies: 2Last Post: 12th Dec 2007, 01:46
