ok. I would first like to point out that my knowledge in converting is pretty well non-existant. but I am trying to learn.
what I'm trying to do is convert my avi files (using DIKO)that I have downloaded off the net into a format that I can use for dvdlab. what happens is with one particular file, it will extract to a MPEG file of the correct size and a MP2 audio file with 0 bytes. I was using amourek's guide which can be found here for reference.here
here is the info that I have on both the files that DIKO converts with no problems and the one that it doesn't extract the audio.
on the ones that work: the v. codec name is DivX v3MPEG-4(low-motion) and the a.1 codec name is MPEG layer-3
on the one that doesn't work: the v.codec name is DivX v3MPEG-4(low-motion) and the z.1 codec name is DivX
audio
if someone could give any help or refer me to another guide that I may have missed with this problem. I would be greatly appreciated.
thank you in advance for any info you can give me
Problem extracting audio from mkv
By Djago in forum Video ConversionReplies: 5Last Post: 12th Jan 2012, 18:57 -
Problem extracting audio from WMV files
By Bully9 in forum AudioReplies: 33Last Post: 21st Jul 2011, 05:27 -
Extracting audio from flv
By Mike99 in forum AudioReplies: 30Last Post: 22nd Apr 2011, 08:31 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 19:03
