my lg 4163b doesnt want to burn cds.
it burns dvds, but says there is no cd burner when i try to burn a cd.
using nero
also i backed up a trailer park boys dvd the other day, and it burned fine , but heres the weird thing: it worked fine for the fist couple of times watching it, but eventually became useless and wawnt play anymore....is this possible?
Try removing the burner from device manager, then rebooting to get windows to reload the drivers. Then I believe there is an option in Nero to have it rescan for devices.
The DVD issue: sometimes cheap media will do this, or the dvd label (assuming you label your discs).Google is your Friend -
thanx for the advice.
the cd thing worked although only for nero...
easy cd creator still doesnt accept it as a cdr drive
(which is cool cause i only use easy cd for extracting audio files)
the dvd thing is questionable cause i used decent quality ritek/ridata dvdr (not the cheap ones either) -
Unless I'm mistaken, I don't remember seeing a rescan option in Roxio. I know it scans on install, but there should be an easier way than re-installing the software.
Pioneer DVR118L Won't Burn CDs
By DarrellS in forum DVD & Blu-ray WritersReplies: 17Last Post: 12th Apr 2011, 03:36 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
How to rip and burn (What to use for both) Karaoke Cds???? Please help. tha
By slayer_of_all in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2010, 20:30 -
Burn 2 CDs at once
By orfajackson in forum Newbie / General discussionsReplies: 2Last Post: 27th Apr 2009, 22:03 -
I can't burn CDs with iTunes.. What do i do?
By just in forum Newbie / General discussionsReplies: 9Last Post: 8th Dec 2008, 06:26
