Hi everyone,
I searched this forum but couldn't find a solution.
Could anyone help me with a problem with Premiere Pro capture? When i connect my camera (a JVC miniDV cam), Premiere recognizes the DVcam as online but says "Can't Activate Camera Controls". I had set the device option to "JVC Standard." Clicking on the PLAY button on the capture window plays the tape on the camera but Premiere Pro doesn't show any preview. I can click on the CAPTURE button but nothing happens.
WinDV, DVIO, Pinnacle Studio, Media Studio Pro and ImageMixer all can control the camera.
I edit my vids in Premiere Pro and I would like to capture in it so I could use its auto scene detection option.
Thanks for the help...
I've never had that problem. You might have a better chance to find someone with the JVC camera in the DMN Premiere forum.
http://www.dmnforums.com/cgi-bin/displaywwugindex.fcgi?forum=adobe_premiere -
Thanks for the link. It seems that Premiere Pro's capture module is a bit finicky if there are other capture devices and audio filters installed. I realize that an analog capture card and its software may be causing conflicts. I hope that is the reason.
I've found several ideas that I could try when I get home tonight.
If it helps others, I found these links from Adobe that discusses the problem:
http://www.adobe.com/support/techdocs/331262.html
http://www.adobe.com/support/techdocs/330682.html
If there are other ideas out there, they would be very appreciated. Thanks very much.
How to control transition length in Vegas Pro 10?
By gutterboy in forum EditingReplies: 4Last Post: 14th Oct 2011, 16:12 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Picture regional control with Premiere - how?
By nmeuncn in forum EditingReplies: 2Last Post: 27th Jun 2009, 11:18 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Looking for motorised DV camera bracket that I can control via the internet
By stephenc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Jun 2007, 12:25
