I own a Toshiba laptop and I am unable to backup a dvd movie onto a dvd-/+R but it will work with a DVD-RW. The process I used is DVD Shrink and then Nero to write. Creating data dvd and music cd's all works with all formats. The only problem is backing up a movie. Any suggestions ?
I would try a different brand of DVD media. Some burners don't like some media. If you can burn RW DVDs, you should be able to use - or +. Check with Toshiba, they should be able to suggest compatible brands.
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56 -
DV to DVD on a laptop?
By daring in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2007, 17:01
