Hello folks,
I am using a PlayTV Pro card with the alternative drivers to capture PAL-M video. I use to set the capturing framerate always to 29.97 , since PAL-M is 60Hz interlaced and my goal is always NTSC VCDs/SVCDs/DVDs.
Will I get a good result if I set the capturing framerate to 25fps to produce a PAL output? Or should I always stick with the 29.97 framarate?
Thank you very much,
Andy
Results 1 to 1 of 1
Need help capturing PAL video input.
By Tobes in forum Capturing and VCRReplies: 10Last Post: 5th Nov 2015, 06:22 -
capturing PAL signal as 1080i, 720p or just PAL ?
By adom in forum Capturing and VCRReplies: 3Last Post: 30th Aug 2011, 05:10 -
Capturing PAL-60 with EasyCap problem!
By neoflame in forum Capturing and VCRReplies: 7Last Post: 18th Jan 2010, 05:56 -
Capturing PAL-M VHS (Brazil) on UK system. Help!
By Killer3737 in forum Capturing and VCRReplies: 13Last Post: 11th Nov 2008, 10:24 -
capturing PAL Beta tape
By sickyd in forum Capturing and VCRReplies: 5Last Post: 1st Aug 2007, 22:14
