    Feb 2003
    When compiling a DVD made of clips from various sources, is there any way to make each of these clips chapters, rather than titles? In other words, can I make a DVD with one title with each clip being a chapter within that title?
  2. Architect can do this,What program are you using?
    Feb 2003
    I was using NeroVision Express but also trying out several trial versions of other programs. I will try Architect.
    Thanks!
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    TMPGEnc DVD Author can also do this.
    If in doubt, Google it.
  5. Member GeorgeW's Avatar
    Feb 2005
    Are you trying to combine all the clips into one long Title? Then have menu buttons that will jump to a chapter, and continue playing from that chapter to the end of the video (i.e. play everything after it)?
    Or do you want to play one clip, then return to a menu?
    Just wondering what you are trying to do in terms of playback and/or dvd navigation...
    George
    Feb 2003
    Thanks for the reply.
    I would say that I am trying to play one long title, without having to return to a menu.
    Thanks!
