Hi, I just started using DVD_Lab Pro and I have a couple of questions. First, how do I have a short video clip play and then jump to the main menu? Second, sometimes after the authoring is done, the audio is out of sync (before files being burn onto DVD). Is there any problem that can put vts files back in sync? Thanks in advance!
Results 1 to 10 of 10
Witness the power of the New Zealand All Blacks!
y have also problem with audio vido sync
read this
https://www.videohelp.com/forum/viewtopic.php?t=270027 -
Thanks for the tip, I'll try the delay correction in dvd-lab pro. Thanks.
Witness the power of the New Zealand All Blacks! -
Thanks, I have been giving this a wrong approach. I tried to make a motion menu as the first menu and wanted to have the menu jump to my second menu. thank you for the advice!
Hi, I read about how to use relax compliancy mode in dvd lab pro but can't find the multiplexing engine in the compiling window.
No, is not in project setting either. I didn't find project settings, so I'm assuming that you are talking about project property.
OK - Properties - didn't have it front of me at the time (still don't so this will be close, just not exact). The setting you are looking for is the allowable resolutions. By default it will be compliant settings only. You ca loosen these here to allow SVCD settings and others. By doing this you are making non-compliant disks that may not play in all players. When you go to compile it will give you a warning about this.
Just looked it up on the DVD Lab online help file at Mediachance - the same one that ships with DVD Lab Pro - the setting you are looking for is under properties and it is called Accept Movie Sizes. RTFM - help is your friend.Read my blog here.
I am trying to use the relaw compliancy mode to fix the audio sync problem because I read it on this: https://www.videohelp.com/forum/viewtopic.php?t=270027.
Please forgive me for not understanding you, but is this " allowable resoultion" the same thing as relax compliancy mode?Witness the power of the New Zealand All Blacks!
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 22:02 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 1st Jan 2010, 00:01 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 05:42 -
DVD Lab Pro
By Flying Doctor in forum Authoring (DVD)Replies: 6Last Post: 16th Jun 2008, 10:00 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 08:53
