I am working on a friends computer that needs wiped and 98 put back on it, the problem is..the floppy drive is some weird combo drive (like floppy and zip drive all in one) and has a IDE interface. All my floppy drives that I have laying around have a smaller connector and what Im wondering is if I can take a 98 bootdisk, and make it into a bootable CD and then set the options in the bios to boot from that and do the fdisk and format and setup like that? Any answers would be appreciated! Thanks
If at first you don't succeed; call it version 1.0
Yes, you can do it exactly that way (create iso of bootdisk, burn, then boot from it).
ok...how do I make an ISO?
If at first you don't succeed; call it version 1.0 -
Actually, if you have Nero, there's an option to make a bootable CD.
Alternately, you can use WinISO. -
ok...I have Nero...thank you so much for the help
How to make a floppy imge from the bootable section of a CD
By nerys in forum ComputerReplies: 5Last Post: 20th Feb 2011, 13:38 -
Floppy Drive Not Recognised
By spliffy in forum ComputerReplies: 38Last Post: 26th May 2010, 02:45 -
Setup cannot read floppy drive
By DarrellS in forum ComputerReplies: 11Last Post: 24th Mar 2010, 03:31 -
What can I replace a Mitsumi DD floppy drive with?
By piano632 in forum ComputerReplies: 8Last Post: 19th Dec 2008, 08:00 -
Floppy diskette seek failure????
By aruwin in forum ComputerReplies: 16Last Post: 2nd Oct 2008, 21:22
