Help. I just installed Nero 6.6.0.13 and it seems to have created a problem with the mapping of my drives, specifically the mapping to my CD recorder. When I go into Explorer I see drives F and G, both as compact disk drives. F was the drive that mapped to my CD recorder. G was created by Nero, I assume, as a CD/DVD ROM. When I click on F now in Explorer, I get an error message indicating F is not accessible. When I go to Nero InfoTools my CD recorder does show up and it does show as mapped to F. Can anyone tell me why I cannot access this drive through Explorer. I have uninstalled and reinstalled the CD recorder, but it makes no difference. I have also uninstalled Nero and it still makes no difference. Any help would be appreciated on how to correct this problem.
Nero is so bug ridden, all their new releases seem to be beta's
assuming, You could use System Restore utility in XP. Restore to a point before the mess up.
I myself don't use Nero cause of the bugs. I use Stomp RecordNow Max and Golden Hawk CDRWIN software. No problems. Alcohol 120% is ok too. -
You don't Daemontools installed, do you ? or another virtual drive application ?
Read my blog here.
invert mapping...
By duffymoon in forum ffmpegX general discussionReplies: 2Last Post: 16th Apr 2009, 02:57 -
problem with my cd/dvd-rw drive or with nero or both!
By NBABE1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2008, 14:20 -
Memory mapping error
By Illusionist in forum ComputerReplies: 1Last Post: 12th Jul 2008, 23:15 -
Optical drive problem with Nero cd
By mikehende in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2008, 17:57 -
[solved] FFMPEG Mapping Question
By Pixelartist in forum LinuxReplies: 5Last Post: 13th Nov 2007, 08:02
