Anyone know if it's possible to do the following with one of these:
1> Remove macrovision?
2> Play back DIVX, AVI,MOV etc via the TV out?
Cheers
i dont have the slightest idea how the videologic works. myself i have a geforce 2 mx 400 for TV out, and a Delta DVD drive.
the DVD drive was the cheapest available, thus it was to expensive to implant macrovision and regioshit. playback of divx, avi, mov? well, i just play-back my screen, so whatever's on it is on my TV.
What you should try (in my newbee opinion) is to run the TV as a secondary monitor and voila. as for macrovision, there aint any anymore after that.
Good Luck
NidoranZ -
Thanks for replying
Unfortuatly, the player software doesn't seem to want to send AVI, DIVX etc files to the video output at all - they are displayed on the monitor OK, but the TV output just shows a black screen - VCD, DVD etc works fine though. -
the MPEG chipset on the card can ONLY decode MPEG1 and MPEG2, not divx and avi. Avi and divx you can only watch on your tv with a tvout graphiccard.
Just got an email from the Videologic tech support people - they said the same, looks like its back to converting to VCD and playing those until I can afford a new graphics card!
Igor
PCI Graphics Card
By blueyonder in forum ComputerReplies: 20Last Post: 6th Jun 2009, 10:40 -
dvr pci card
By platonas in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 03:37 -
Unable to transfer some VHS to DVD using AverDVD EzMaker PCI Card
By fromvn in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2008, 11:38 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
