I have a ripped DVD of 24 (~4 gigs) and in one of the episodes the commentary is mixed in. Is there a way to shut these people up? The odd thing is it is only in one episode of the dvd, the other episodes are fine. Thanks!
I suspect you have ripped the commentary instead of the episode track. You will have to go back to the original disk and rip it aagin to correct the problem. The verify if this is the case, you need to open the episode in something that can show you the number of tracks, or just try to change tracks with the audio button when it plays. If you cant change tracks or only have one track then you are screwed and need to get the original episode audio back from the original DVD.
Read my blog here.
Man I don't know why changing the track before didn't work, but I gave it one last try and it worked. Thanks
How can I add an audio commentary to a dvd?
By artyjeffrey in forum Authoring (DVD)Replies: 1Last Post: 28th Nov 2009, 04:44 -
Audio Commentary
By Anonymous234 in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2009, 21:02 -
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 12:57 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
how to add commentary over dvd audio?
By Denvers Dawgs in forum AudioReplies: 3Last Post: 24th Nov 2007, 00:58
