I haven't touched it in over a year and a half. What are the new products out there that are used for video editing/dvd creating. Also, what could I use for dvd capturing? Are there just card that you have to put in your computer or do those external USB devices work as well too? Any info or pointing me in the right direction would be great. Thanks for your time.
"Wanting people to listen, you can't just tap them on the shoulder anymore.
You have to hit them with a sledgehammer,
and then you'll notice you've got their strict attention."
-John Doe in Se7en -
There's tons of products, most if not all have free trial periods.
To get video off a DVD it can be as easy as coipying the .vob file to your comp and changing the extension to .mpg, if that doesn't work or you want some more options try DVD Decrypter.
Capture card depends on your budget and what you want to do with the video. For AVI capture I'd suggest a Canopus ADVC or if your in the market buy a new DV cam with passthrough capability. For direct mpeg capture many seem to prefer the Hauppage 250 or simply using a DVD recorder and transferring to PC for edit. There are diffewrent and cheaper solutions as well but the qabove 4 I mentioned seem to be the least troublesome.
Pinnacle Quick Studio 10 question
By dbanimal in forum Authoring (DVD)Replies: 2Last Post: 24th Apr 2009, 15:21 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48 -
Pinnacle studio quick start help need
By littlesweetboy in forum EditingReplies: 4Last Post: 7th May 2007, 04:46
