Hi
A friend of mine gave me two AVI files that were encoded in AC3 DVM and XVID. I checked the codecs using AVICodec. I really want to conver them to MPG so that I can rip them in DVD format to play on my DVD player.
I used Virtual Dub which can open the AVI and can save it also to AVI, which I thought might work to open and combine both AVI's in Sony Vegas but the problem is that Virtual DUb can not read the Audio part saying that compression is not supported.
I appreciate if you can guide me to an easier way to convert those files into MPEG so that I can rip them
I'd start with VSO DivxtoDVD. It should be able to convert both files to DVD, and probably make them fit on a single disk. Then use Tmpgenc DVD Author or DVD Lab to create menus (if you really need them)
Read my blog here.
At a guess I'd say that Virtualdub saying the audio is not supported is possibly because you don't have an AC3 codec installed. This is then backed up by the fact that DivxtoDVD leaves you without audio. Look for AC3 Filter in the Tools section
If in doubt, Google it.
ac3 audio and xvid video in avi out of sync
By socrates in forum Video ConversionReplies: 10Last Post: 15th Jul 2011, 22:58 -
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 06:59 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35
