  1. with all the dvd players stand alone types on the market that make dvd with commercials
    Now what would be nice is a program that will let me edit out the commercials from the vob file and then save it back to a vob file or dvd format
    without ripping out the movie and the sound first and converting back to avi.
    there must be a simple program about
    also one that can blank out the lower section as much as required .
  2. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    There are plenty of basic editors, but I'd suggest Womble MPEG Video Wizard if you intend to do anything extra (i.e. transitions, cropping, level adjustments, etc.) MVW comes with a 30 day free trial period. BEWARE: Once you try it, you won't be satisfied with one of the simple editors.
    Here's a link to the basic editors.
    https://www.videohelp.com/tools?s=107#107
    Good Luck!
  3. Member daamon's Avatar
    Melbourne, Oz
    VideoReDo is regularly recommended too.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
