HI,
I hope this is the right forum for this question, maybe I should put it in the newbie section. I have a Pioneer DVD-RW drive, it will read and write to reg cd's and DVD's, but it will not read or write to any cd-rw's. I guess what I am asking is will a DVD-RW read and write to cd-rw's? If so could there be a solution to this? Thanks.
It should, but it may depend on what discs you have. Your drive only supports up to 4x and 10x CD-RW discs (high-speed). 24x CD-RW discs will not work.
You could also try using another brand. Keep in mind RW media is not ment for long term storage, as discs can go bad.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
The disks say 1x,2x and 4x. Thanks for the info about long term storage, thats what they would of been used for. Are the cd+rw's better?
If you want long term storage, write once media (CD-R, DVD-R, DVD+R) are your best bet. All rewritable media uses phase shift technology. This means the recording layer is actually made up of a crystaline like structure which changes shape and properties when a laster hits it. These crystals are far less stable than the dyes used in write once media, and can lose their form over time which can result in data loss.
Use high quality write once media, like Taiyo Yuden, MCC, or Maxell.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 08:57 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 14:21 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 19:00
