Why would you use DVD Shrink on a disc made off a DVD recorder?![]()
Results 31 to 39 of 39
I record DVD off the cable on DVD+R/W, with the commercials, I then edit out just the video into a DVD, for related eposide and stuff.
DVD shrink 3.2 can combines video from multiple DVDs, plus folder into one DVD.
If DVR1600 records on DVD+R, all is well. But DVDR1600 records odd format on DVD+R/W. It look like double sessions.
I currently have to copy the video_ts folders to HD, and use TDA to compile. -
I do this as well. Shrink is a good, free, simple tool for this, if you don't need menus. No compression involved.
I had Comcast digital and downgraded it to standard. The reason is I added a Dish, but wanted to keep local channels for bad weather when the Dish lost reception.Originally Posted by SingSing
Comcast digital is not comparable to Comcast "standard". Not even close. -
One of the big different between DVR1600 vs those ) MOney x 2 = $199.00 ) DVR is "DVR1600 has firewire". For DVcam owner, that is a much have ! Doh...
The ghosting is probably due to a poorly screened SCART lead. Get a decent heavy duty "all cables screened" lead and the problem should go away. Incidently, I only use Cyberhome DVD players as I find they are very reliable and will play anything - I also like a machine that has it's own hack site on the web! I have no experience of their recorders but would imagine they would be of similar quality to the Liteons and other cheap brands. Obviously a JVC or Pioneer at four times the price will yield better results, but we don't all have money to burn.Originally Posted by zeldadog
You may still be able to find the "hackable" LiteOn 5005 for $99. You can remove region, add 3 hr speed, and remove macrovision. LiteOn makes optical drives (DVD writers) themselves, just added the recorder part to it.
Disabling macrovision remover will be a big plus compare to DVR1600.
I wonder Liteon has a better result recording from TV tuner ? -
I purchased a DVR-1600 a month ago and Im happily surprised that it plays DIVX and XVID, it even recognized SRT subtitles.
What royally pisses me is that the Divx subtitles are MAJOR CRAP, they appear in the middle left side of the screen, and have no black outline, so if you have a white image, you dont see them at all.
I know for sure this can be fixed on the firmware level because I have a philips player that suffered of something similar, and after a firmware upgrade it was solved.
My unit have firmware MU1 just in case.
CYBERHOME ARE YOU LISTENING? This is a great recorder/player for its price, but the divx functionality puts it on the not so good category...
Any one with a non working cyberhome dvr-1200 or 1600 will buy your remote
By therd3 in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2010, 01:21 -
problem with cyberhome ch-dvr player/recorder
By kayjay3k in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2010, 17:27 -
Need firmware for CyberHome DVR-1200 (MU)
By Man In Black in forum DVD & Blu-ray RecordersReplies: 7Last Post: 25th Jul 2009, 22:46 -
DVR to DVD recorder copying
By Boltsfan22 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 18th Oct 2008, 17:02 -
CyberHome DVD Recorder
By JRPAT in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Sep 2008, 19:08
