  1. i have a movie that is 1.3gb in size and it is broken up into 20 parts, i believe called bin and cue . how do i use nero to put all these parts together and make one complete movie.........any info would be great.
  2. IF you do have the bin/cue files you can open nero and close the wizard/help window and depending on your version click either file>burn image or in newer versions its recorder>burn image. Select the cue file in the browse window that pops up and then burn.
    Dunno if thats what you needed, but from what you said it should be that simple.
    Good luck
  3. what version is the best and easiest to work with it......
  4. I have gone thru several versions of Nero over the past few years and they were all very easy and worked well. I upgrade to a newer version every once in awhile and never have a problem. I'd say in my opinnion any version released in the past 3 or 4 years is a safe bet, but the latest versions are always supposed to be a bit better.
  5. you say files are in about 20 bits whats extension of these bits
