How do i know if my new standalone LG LDA-530 uses a ess chip set or not? I looked on this site and on lg site, my manual and google but could not find out? to use auto-g2k you need to changing a setting if you have a player with ess chip set. anyone know or know how i could i find out?
thanks
mick
Remove the cover,look at mainboard inside for a large square chip,is it marked ESS?
Could do a search and see if anyone else has ripped on open yet or run a test. ESS doesn't support qpel, although I guess it isn't the only chipset that doesn't.
The menu's I would also imagine should be a bit of a give away.
LG players use MTK chipsets here though and judging from the info here: https://www.videohelp.com/dvdplayers.php?DVDnameid=5647&Search=Search&orderby=Name I would say that it does to. LG here doesn't have issues with packed bitstream and > 1 bframe like some MTK based players either. -
Just an update. i made a xvid with autog2k and i choose not to use ess sopport, the xvid worked perfect. so i would assume its not an ess based chipset.
If you find out what chipset it is don't forget to post it in the dvd player list, https://www.videohelp.com/dvdplayers.php?DVDnameid=5647&Search=Search&orderby=Name (click add report).
im planning on filing a report after i have used the player for a week or so, i want to try all or most of the formats so i can report on them.
Does a Motherboard's Chipset Make a Difference?
By wulf109 in forum ComputerReplies: 1Last Post: 20th Oct 2011, 11:43 -
SAA7130HL Chipset Off Brand Tv Tuner Card
By zeobo in forum Capturing and VCRReplies: 1Last Post: 2nd Nov 2009, 16:39 -
945 Intel chipset have hdmi problems?
By kasol in forum Media Center PC / MediaCentersReplies: 7Last Post: 9th Jun 2009, 02:52 -
Best tv tuner chipset just for getting channels best
By blitter2 in forum Capturing and VCRReplies: 0Last Post: 26th Dec 2008, 09:01 -
AutoGK - Reencoding for ESS Compatiblity - MAINTAIN SAME FILE SIZE?
By GrayStrickland in forum Video ConversionReplies: 1Last Post: 27th Sep 2008, 12:59
