Just bought a lite-on 5045. Hope I haven't messed up. Has a date of Nov 2004 on the box. Visiting son and won't be able to test it out till next week. Wished I could have found a newer date but I had to take what I could get because the Costco's in my area do not sell these. Any thoughts? Thanks!![]()
Date doesn't really matter that much. It will probably be a difference in the firmware that is factory loaded on the recorder. Just update the firmware once you get it set up.
The 5045 is a darn nice recorder. I've been using one for about 3 months and it has only messed up once ; it didn't make a +RW disc readable. I always thought that +RW media didn't need to be finalized (and it doesn't in the normal sense), but after the 5045 finished writing a program to the +RW is DOES do something to the data while the unit is flashing STOPPING on the display.
I think you will enjoy your 5045.Proud Member of the Unofficial LiteOn/iLO Beta Testers Club.
Upgrade Liteon lvw-5045 to 400G successfully
By totoro168 in forum DVD & Blu-ray RecordersReplies: 237Last Post: 27th Feb 2023, 17:53 -
lite-on LVW-5045
By pmitch in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Mar 2009, 04:44 -
Lite-On lvw-5004 (europe) question
By dynalink_user in forum DVD & Blu-ray RecordersReplies: 1Last Post: 16th Aug 2007, 08:53 -
Lite on HD-A740GX input question/problem
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:32 -
LiteOn Lvw-5045 (UK - English)
By cubud in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Jun 2007, 15:05
