Is it at all possible to convert, lets say a DIVX AVI to an MPEG-1 VCD compliant video file with the same exact picture and frame quality from the DIVX file with TMPGEnc? I only wish to create a VCD and nothing else. If it is possible, what settings do I need to set to get the result? Thanks in advance.
GFour
everybody wants to do that; only sofar everybody failed.
DivX uses MPEG4 technology. VCD is MPEG1 ,logically its worse, or should i say, different then the DivX MPEG4, and therefor you cant build the MPEG1 (VCD) pictures the same way as with MPEG4 (DivX).
It should however be possible to use the divx coding which is compatible with MPEG1, and rewrite the non-mpeg1 parts. however, so far i know zero programs capable to doing this.
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
(Picture) Tmpgenc DVD Author 3 Question
By Maikeru-sama in forum Authoring (DVD)Replies: 0Last Post: 3rd May 2008, 18:20 -
question about how to make picture brighter in TMPGEnc DVD Author3
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:08 -
Question regarding DVD picture quality
By Neutral-Sage in forum Authoring (DVD)Replies: 7Last Post: 5th Nov 2007, 18:34 -
Picture Quality Question on made DVD
By Superstar24 in forum Newbie / General discussionsReplies: 24Last Post: 26th May 2007, 00:35
