Now DVD media is so cheap I've just started converting VHS home videos to a more convenient format and editing them with a DV editor.
I've captured the VHS by playing on a Sony SLV E700 recording on a Toshiba RDXS32SB to a Fujifilm DVD-RW DVD disc. The results show no deterioration on TV or PC. To edit I need to convert to AVI DVD2AVI etc.resulting AVI still no problem.
After editing I need to render before reauthoring. After this stage scenes with motion seem blurred. No block distortion sometimes found with VCDs etc. but enough to make the viewer dizzy. I've tried to use Vegas, Premiere 6 & Pinnacle Studio 7 all of which I've used for dv edting without this problem.
Can anyone help please?
R.A.J.
Sounds more like the software is deinterlacing. The source, having been captured onto a DVD-RW on a DVD recorder, is most definitely interlaced.
I would use VirtualDub for converting to uncompressed AVI.
And then be careful when settings up the project settings in Premiere. None of them are TFF interlace by default.Want my help? Ask here! (not via PM!)
Thanks Guys I thought about interlacing, but...
I tried the MPG2 version of VDub which accepts VOB files direct from DVD. Produced uncompressed AVI about 9GB for 5 minutes. Too big to view but Vegas & Premiere accept OK. Render with both Upper & Lower fields first produces AVI of about 1 GB but with original problem. I see VDub has a field order setting for preview. Does this have any bearing on output?
Perhaps I'm missing something or misunderstood. Any further comments welcomed.
Subs fat and blurred on VOBs on my Hard disk, Not on DVD
By stumerr in forum Newbie / General discussionsReplies: 4Last Post: 20th Jun 2010, 00:17 -
Blurred Text on DVD Menu
By boofer in forum Authoring (DVD)Replies: 3Last Post: 10th Jan 2009, 18:45 -
Motion "jitter" on vhs to dvd but corrects if dvd player paused t
By victoriabears in forum Video ConversionReplies: 3Last Post: 16th Jul 2008, 18:16 -
DVD Lab - menu text blurred (PAL)
By BeachNut in forum Authoring (DVD)Replies: 12Last Post: 21st Jan 2008, 07:12 -
VHS to DVD conversion
By elia12978 in forum Capturing and VCRReplies: 16Last Post: 13th Jan 2008, 18:42
