Hi all,
I have just one big question?
The SVCD sample that is on this site seems to be better that all the tests I have done. I know it is 480 x 480 at 2500 bits but can someone tell me what software and filters was used to make it?
My tests come out good but the fast motion thing is killing me.
jw9800,
Hope you're still awake!
I see that nobody has answered your post. My guess is that the origonater
of the clips is no longer available or lost his/her specs to those caps you
D/L'ed. So, I'll just share my caps with ya, since VCDhelp doesn't have a
link to my site.
In your SVCD comotion, I thought you would like to D/L a sample (new) that
I added to my website for your viewing. You can compare it to the ones
you said you D/L'ed and see if this kind of quality compares better or worse!
These caps that I make gives the best all around Quality... trust me!
...AND speed while encoding from avi with these resolutions.
I believe that those clips you D/L were done it real-time mpeg captures. So,
you'll no doubt find some differences in quality. Have a looks'eez and, enjoy
the video!
Please view my thread I started this in:
* https://www.videohelp.com/phpBB/viewtopic.php?topic=70370&forum=10&0
<font size=-1>[ This Message was edited by: vhelp on 2001-12-16 23:17:35 ]</font>
Premiere and sample rates
By tpapictures in forum EditingReplies: 6Last Post: 4th Apr 2011, 20:05 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
SDK sample codes.
By suefyzah in forum Capturing and VCRReplies: 7Last Post: 29th Jul 2008, 22:12 -
Sample Rate Differences?!
By GangstaRap in forum Video ConversionReplies: 1Last Post: 27th Dec 2007, 05:28 -
NeroVision 3 Sample format?
By LiBiDoXP in forum Video ConversionReplies: 0Last Post: 1st Jul 2007, 12:50
