hey guyz
what codec do you need to play mkv files?
Depends what is in the mkv. mkv files can contain numerous audio and video streams.
i dled the codec that you have told me about....
i tried to play it.. but it still cannot work....
any other ideas? i tried using it on VLAN too.. but i cannot see the pic..
in my windows media player clasic.. there is no sound.. but when i put in on vlan there are sounds... but both of it don't have any pic
any idea?
thx in advance -
To play an mkv file you need
1) an mkv parser filter such as Haali's found in the most recent mkv pack. VLC has one built in.
2) A decoder for whatever video stream. VLC has numerous built in, however it can't handle everything that can be used in mkv.
3) A decoder for the audio stream(s). VLC also includes various audio decoders.
4) A subtitle filter if it uses subtitles (included in VLC).
Like I said it all depends on what is in the mkv file. There is no one codec that can decode all possible combos. mplayer can play I would think every mkv file though, including those containing Real Video. First player to support menus in mkv is I believe going to be VLC.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
how to join mkv.a and mkv.b files
By sumeshkri in forum EditingReplies: 1Last Post: 5th Apr 2012, 19:56 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45
