what is thae best way to to convert avi/xvid to dvd and still get good quality
i have used TMPGEnc 3.0 Xpress to go to mpg then i used nero togo dvd.
theen i found a way that DJRumpy uses but i can not figure it out can ne1 help me
Quality is primarily dependant on your source, your bitrate, your resolution, and the filters you use, to name just a couple of factors. http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might help you with selecting appropriate bitrates and resolution.
If in doubt, Google it.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
