I just authored a dvd using a simple BMP screenshot with a PLAY button and the movie. I then thought of somehow adding some sort of pre/post menu stuff, to give it some kind of 'feel', you know?
Are there any user created inserts out there that's available for usage? I found some at http://www.dvdshrink.info/goodies.php but there should be more out there...
Any that you all can think of?
Thanks,
Joe
The first guide is how to add pre and post commands using pgcedit
All these guides listed are a valuable starters pack
From avi files all the way to mastered dvd using freeware
https://www.videohelp.com/forum/viewtopic.php?t=270121
https://www.videohelp.com/forum/viewtopic.php?t=270071
https://www.videohelp.com/forum/viewtopic.php?t=269499
Hope these give you some answers you want .
As for pgcedit , I have only had it for a few months , but will help you when ever possible with those commands .
Menu created with jpeg2yuv/mpeg2enc/spumux looks bad
By Bigfoot73 in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 15:14 -
Adding menu to DVDI created with The Film Machine?
By naoise in forum Authoring (DVD)Replies: 0Last Post: 10th Dec 2009, 03:08 -
How can I use an existing motion menu, on a newly created dvd?
By Denvers Dawgs in forum Authoring (DVD)Replies: 13Last Post: 23rd Jun 2009, 16:09 -
How do I create a DVD menu for a slideshow project that I created?
By wsmitty in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2009, 19:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 12:46
