Results 1 to 14 of 14
  1. Yes, they are good. Supermediastore has them for the same price too.
  2. well i heard they are not the "best" TY
    So i was wondering if these were better than the "Value" ones
    Don't believe everything you hear.
    They are good.
  4. I've had a couple of bad ones out of a few hundred.
    Jun 2004
    USA
    I have had (1) bad out of 300+ TY that I purchased from Meritline.
    bits
  6. sounds quite decent. Thanks
  7. GREAT media! I've burned a ton of these at 8x on my NEC 2510 with only 3 bad burns out of 250+
    AND a great price also!!
    Sing while you may.........
  8. Member zoobie's Avatar
    Feb 2005
    Florida
    Noticed the 100 pack is now on sale with $8 off for $24.99 + ship
    Dec 2003
    Houston,Tx
    Do these come in the spindle?
    "What It Do"
    Huh ?????
  10. Member zoobie's Avatar
    Feb 2005
    Florida
    ...or here for $28.80 shipping included
    http://www.shop4tech.com/user.htm?go=view_item&id=3007&cata=1&s_cata=
    with the discount code xpbargains10
  11. They don't come with a spindle.
    Still a few bugs in the system...
    Aug 2004
    Oshkosh, USA
    I've gotten about 1200 of these in the last 6 months or so, I've had about, oh.....<thinking>.....5 bad discs. I've been *very* happy with them. Hoping to order more in a week or so, although I may try to "TY" 8x at Allmedia.com if I hear good things about it.
    The couple of bad ones I had were those on the top and bottom, I think. I can't be sure. And they do NOT come with spindles, unfortunately. If they did though, the shipping would cost more probably. They come in a shrinkwrapped/sticky film plastic.
    My gear:
    - JVC HR-S9911U SVHS VCR
    - Datavideo TBC-1000
    - JVC DR-M10 DVD writer
    - Sony Steadyshot DCR-TRV340 NTSC Digital8 Camcorder
