  1. I can never remember is the 8GB stuff now called Dual Layer or Double layer?
    anyway whats the difference between the + and the - formats. I remember the differences in the single layer when that started out.
    if I eventually get a DL burner once the media drops in price and I can do both, what are my advantages to one ober the other.
    thanks rotut
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
  2. Originally Posted by rotuts
    +DL = "Double layer",
    -DL = "Dual Layer".
  3. really? don't know joe
    can't make heads or tails of the
    mabe a ?
    r
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  4. Wow Joe!
    who knew!!
    now what the difference and how do you choose if your recorder makes both? in the old days it wsa said that the DVD-R singles played on more set top DVD palyers.
    R
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  5. I would choose Verbatim DL media:
    https://www.videohelp.com/dvdmedia.php?dvdmediasearch=verbatim&dvdmediadvdridsearch=&ty...+or+List+Media
    With +DL there is currently more experience available. Bit-setting from +DL to DVD-ROM may help regarding compatibility. Layer break is a problem with some burning SW.
  6. thanksfor so much info joeg
    R
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
  7. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I have used 7 Verbatim +DL with no problems playing on my Toshiba, Sylvania, Sony, or even my crappy samsung that is picky with media.
    What We Do In Life, Echoes In Eternity....
