I just bought myself a copy of the chapelle show season 2.
i want to back it up but i have a problem. i dont care for the extras but i still want a functional menu.
i use dvddecrypter then dvd shrink. when i use dvdshrink the menu is non-functioning.
how can i get the menus to be functioning ??
P.S. .. i want the original menu that came in the dvd , not those cheesy DVDauthor ones
You can use DVD Shrink - just replace the extras with a black still (create a simple black bmp) - only in reauthor mode will you kill the menus. Or use something like vobblanker, which takes us even less space.
Read my blog here.
To keep a functioning menu when backing up a movie I use Vobblanker to blank all the parts I dont want, I just leave the main movie and the menu.
I use PGCedit to blank menu buttons that are not required and just leave the 'Play Movie' button functioning.
I then compress with shrink if required and burn to disc with DVDdecrypter.
When doing it this way always make sure the DVD is functioning how you want it to be, with a software player first such as WINDVD, or POWERDVD, before burning to disc.
Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
By Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 17:02 -
Door/tray stuck problems.... solution?
By garybeck in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jul 2009, 16:09 -
menu problems
By jerichoy2j316 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2009, 11:13 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Menu Problems - No Roll Overs - Where are I in the menu?
By dunncha in forum SVCD2DVD & VOB2MPGReplies: 81Last Post: 10th Nov 2007, 07:40
