  1. Hi I purchased two banks of 128 MB PC-133 Sdram.
    The problem is that I can't use them at 133 Mhz of frequency...the pc won't boot...I have to unplug the two banks of Sdram and set the freqeuncy at 100 Mhz.
    The 256 MB stick instead work at 100 Mhz or 133 Mhz without any problem on booting.
    My motherboard is a KT133A chipset VT82C686A
    Here is the Everest Sdram report:
    Thanks for any help!
  2. Blame it on your Processors Clock Multiplier and MotherBoards Front Side Bus.
    You can try to overclock your system to make your RAM run at 133Mhz but I would'nt recommend it.
