Newbie here. I had been using wireless headphones with independent volume control on them hooked up to the audio outputs. They quit on me, so I am now trying to use normal wired headphones that have no volume control to watch a DVD, but can't figure out a way to adjust the volume. I've increased the input level to +6dB, which helps a little, bit not enough. Have limited outputs on the tv, so that does not appear to be an option. Trying to work it so others can listen to audio normally thru TV speakers, but at the same time I am using the headphones to listen to the same DVD, as I have some hearing difficulties.
I'd purchase a small audio amplifier for the headphones. The line input to the amplifier would be connected to the line output on the back of the Pioneer. If necessary, you could even use Y cables to split the audio to a second device. You should be able to find a suitable audio amplifer at Radio Shack, Best Buy, Frey's, etc.
Good Luck!
Connecting headphones
By siluet in forum DVB / IPTVReplies: 5Last Post: 14th Jan 2011, 09:22 -
Can Anyone Recommend A HQ Pair Of Headphones?
By Nitro89 in forum Off topicReplies: 6Last Post: 5th Nov 2009, 10:23 -
Pioneer 510-H Won't Power Up
By groberson in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st May 2009, 00:11 -
Best Headphones
By Nitro89 in forum Off topicReplies: 26Last Post: 11th Dec 2008, 17:37 -
What grade of headphones do you buy?
By yoda313 in forum PollsReplies: 23Last Post: 25th Jun 2007, 20:12
