I currently have virtually no cooling; I'm afraid my system is going to overheat on me this summer. I want to create a system that is both cool and quiet. It doesn't have to be a silent system, but I would like it to be fairly quiet. Can you recommend me case fans, a good quiet HSF, and a quiet powersupply? I really appreciate your help. Here's my setup so you can get a good idea of what my heat output is, and what kind of cooling my case allows for.
Thanks so much for your time,
-Jonathan.
Case: MAXTOP Signature CSX-147K2F
CPU: Desktop Barton 2500 333 MHZ FSB w/stock HSF running at stock speed
RAM: 512 MB PC3200 Corsair XMS
PSU: SPARKLE FSP350-60BT 350W
Vid. Card: Radeon 9500 softmodded@9700
Drives: Generic 16X DVD Drive, NEC 2500A DVD-RW/+RW, 120GB Western Digital 8 MB cache version
Here's one link to quiet computers: http://www.overclockers.com/tips1064/index02.asp
For other suggestions, try a Google search for "Quiet Computers".
Probably the main changes are a quiet CPU cooler, then power supply, and finally case fans. The main thing is bigger, slower fans to reduce fan noise. Beyond that is drive noise, if that bothers you.
I like at least one intake fan blowing over the hard drives and at least one exhaust fan on the rear of the case. The Barton runs warm, but unless you are overclocking you should be able to get away with a reasonably priced quiet CPU cooler.
ripbot setting
By miss in forum Blu-ray RippingReplies: 3Last Post: 8th Aug 2009, 08:10 -
PS3 HD setting?
By duketuring in forum ffmpegX general discussionReplies: 0Last Post: 15th Oct 2008, 10:02 -
which project setting?
By wingfan in forum Newbie / General discussionsReplies: 2Last Post: 30th Aug 2008, 09:36 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 19:58 -
I want some suggestions for setting up a speaker system
By wan2no in forum AudioReplies: 4Last Post: 11th Aug 2007, 23:09
