I am kinda new to this...I started backing up my DVD movies last month, then suddenly one day I wanted to finish my backups and I opened the programs and went through the process as usual and I got an error message...the message is "Reporting invalid address for write during recovery - trying to continue. write error - code 03 0c 00 [write error] - info 0 - csi 0" the estimated time is 2 hours to burn, and 2 hours later it says the same thing, i left for work one night and left it on and 12 hours later when i returned from work it still said 2 hours. im not sure what to do anymore, i thought it was the pc, so i rebooted, i've reinstalled the programs...can someone please help me? The software that i am using to back up my movies is dvd decrypeter, copy to dvd and dvd2one. i've also tried nero 6 and a few others, but all of the programs are doing the same. i would appreciate any help that u can give me. thanks.
Results 1 to 11 of 11
We need a better explanation of what your doing.
Tell us the software you are using, the process you are using and what software you are getting the errors with and when ?
What do you mean by 'finish my backups' - do you mean burn to disc ?
More info = better/faster help.
Thanks -
Sorry about that, the software that im using is....dvd2one, copy to dvd and dvd decrypter. i use dvd decrypter first and extract the files to a folder, then i open dvd2one and select the files and check burn files with copy to dvd. it starts to extract and thats when i get the message. the software that i get the message with is the copytodvd. but i have also tried different software like nero and clonedvd and a few others but they are all doing the same thing. what i mean by finish my dvd's is that i had started backing up my dvd's i have a huge library of dvd's that i purchased, and i managed to back up about 15 of them on my days off of work and went back to work, i decided when i went on my days off again and i would finish backing the rest of them up. sorry for not giving enough information. if there is anything else u need to know let me know. i'll try to answer as much as i know.
OK, Are you using the latest version of DVDdecrypter, it is 3.5.4.0 ?
If not I would update to this and then get DVDshrink.
Use DVDdecrypter to rip the DVD to a hard drive folder in File mode for a DVD-9 (8.5GB)DVD or ISO Read mode if the original is a DVD-5 (4.7GB).
If the original is a DVD-5 you can then burn the ISO image straight to DVD-/+R with DVDdecrypter in ISO write mode.
If the original is a DVD-9 movie you can then use DVDshrink to compress/reauthor the movie to fit to a DVD-/+R(4.7GB).
Backup the shrink created DVD to an ISO image and then burn with DVDdecrypter.
I would recommend that if you are unfamiliar with either DVDshrink or DVDdecrypter that you spend a little while checking out the guides section on the left of this page - there you will find many guides on how to use both of these excellent pieces of software.
I use these all the time and never have any probs.
Your best bet would be to check out the DVD backup guide section.
You can also find some good DVDshrink guides at www.dvdshrink.info.
Give it a try, and if you need any more help just ask
And always use DVDdecrypter to rip your original DVD's as it can handle the new copy protection schemes better than DVDshrink can.
DVDdecrypter and DVDshrink are also FREE and produce great results so why spend your money on software when you dont need to. -
I'm gonna try that right now, thanks for the help I really appreciate it. I hope this works.
i tried it....got the following error....
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=30208 bytes, created 6/11/1997 7:01:02 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero API version: 6.6.0.13
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 13c
Recorder: <PHILIPS DVD+-RW DVD8631> Version: 9D03 - HA 0 TA 1 - 6.6.0.13
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
CdRomPeripheral : SAMSUNG DVD-ROM SD-616E atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PHILIPS DVD+-RW DVD8631 atapi Port 0 ID 1 DMA: On
DiskPeripheral : WDC WD800JD-75JNA0 atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
SAMSUNG DVD-ROM SD-616E D: CDRom0
PHILIPS DVD+-RW DVD8631 E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (522316kB)
Free physical memory: 90MB (92964kB)
Memory in use : 82 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
27.5.2005
NeroAPI
6:46:09 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
6:46:09 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
6:46:09 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
6:46:09 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
6:46:09 PM #5 Text 0 File Writer.cpp, Line 122
Writer PHILIPS DVD+-RW DVD8631 running
6:46:09 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
6:46:09 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
6:46:09 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3293
6:46:09 PM #9 Text 0 File Burncd.cpp, Line 3167
Turn on Disc-At-Once, using DVD media
6:46:09 PM #10 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286527 (508:07.02, 4465MB)
6:46:09 PM #11 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO
6:46:09 PM #12 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: PHILIPS DVD+-RW DVD8631, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AE1
Disc Application Code: 64, Disc Physical Code: 193
6:46:09 PM #13 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
6:46:09 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286528 (2286528) = #2286528/508:7.3
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286528 blocks [PHILIPS DVD+-RW DVD8631]
6:46:09 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PHILIPS DVD+-RW DVD8631] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682809344, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286528 | lead-out | 1 | 0x41 | 0x00
6:46:10 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
6:46:10 PM #17 Text 0 File Burncd.cpp, Line 4051
Cache writing successful.
6:46:10 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
6:46:10 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 8x (11,080 KB/s)
6:46:10 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
6:46:10 PM #21 Text 0 File DVDR.cpp, Line 2267
Recording mode: Sequential Recording Mode
6:46:10 PM #22 Text 0 File Mmc.cpp, Line 21469
Set BUFE: Buffer underrun protection -> ON
6:46:10 PM #23 Text 0 File DVDR.cpp, Line 2421
Start write address at LBA 0
DVD high compatibility mode: Yes
6:46:10 PM #24 Text 0 File Cdrdrv.cpp, Line 8438
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
6:47:40 PM #25 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0B1F0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x00
6:47:40 PM #26 CDR -1135 File Writer.cpp, Line 311
Write error
6:47:40 PM #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
6:47:40 PM #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
6:47:40 PM #29 Text 0 File DVDR.cpp, Line 2658
EndDAO: Last written address was -1
6:47:40 PM #30 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 8x (11,080 KB/s)
6:47:40 PM #31 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
6:47:40 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 3:07:32 PM
File 'Drivers\PXHELP20.SYS': Ver=2.03.16a, size=20576 bytes, created 8/2/2004 3:03:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
Ok, at what stage did you get this error ?
Are you using DVDdecrypter to burn or are you using Nero - the reason I ask is that at the start of the error there is a reference to Nero ? -
I used dvd decrypter to try to burn it and i got the message when it was trying to burn, same time i always get the message. people have told me to make sure the dma settings are right i've done that...i've pretty much tried everything. reinstalling, i also purchased another dvd burner thought maybe it was the burner but now i have 3 burners and they are all doing the same. it was working fine when i first got the software and installed it and one of my coworkers is using the same programs but not having any trouble with them.
I'm having a problem backing up Are we there yet.DVDshrink gets to about 27-31% of analyzing the disk then I get an error(cyclic redundancy error).tried 2 burners 2 machines and 2 different dvd roms.Another guy I no had the same problem with anydcd and dvddecryptor.Any help would be great Thanks
Stone1721 just use DVDdecrypter and make sure its the latest version.
Do a search for 'are we there yet' and you will find a few people are having this problem !
Check out those posts for more info !
Meanwhile raggedyann20022002 I'm a little stumped at the moment with this one.
Can you let us know your PC specs, OS, service packs etc.
Have you changed anything on the PC since your burning process was working ok ?
Have you tried using different media ?
Has anyone else had a problem similar to this ? If so can you help ? -
Take a look at the DVDdecrypter support forum, you may find some help there,
Here's the link, http://forum.dvddecrypter.com/
By the way is your DVDwriter firmware up to date ?
If it isn't I would suggest getting the latest firmware and always keep it up to date.
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 31st Oct 2011, 23:11 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 18:18 -
burning problem with backing up my dvd's
By sscottsa315 in forum Authoring (DVD)Replies: 8Last Post: 5th Mar 2009, 20:36 -
Backing-up Vhs movie tapes to Dvd
By Gerald Sr. in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2008, 23:23 -
Order in which to process the backing up of a movie
By Hurre in forum Authoring (DVD)Replies: 11Last Post: 7th Apr 2008, 09:09
