I know how to create a graphic layer mask in Vegas, from grafic file (save in png format) but I want to know if it's possible (I'm sure it is) to create mask from video file, with transparent hole in the middle. Some time ago, I found on internet how to create such a layer mask using vizualisations from windows media player (save it with some programm grab in avi file) and then produce a layer mask, but it was for premiere. If somebody know how to create such a mask in Vegas please post reply.
Regards, Macedonia.
QUALITY HAS A NAME
if i understand correctly, you just want a 'hole' in a video so that another video can play through?
just use the cookie cutter FX and you can size the shapes available and add feather to it.
or if you're on version 5 or 6, you can use the bezier mask to draw your custom shape.
Overlay/Mask/Layer Question
By legocrazy1 in forum EditingReplies: 3Last Post: 16th Jul 2010, 04:00 -
Creating Streamable .mp4 videos from Vegas
By spgvideo in forum Video Streaming DownloadingReplies: 8Last Post: 13th Feb 2010, 09:05 -
Creating clips with Vegas
By Abas-Avara in forum EditingReplies: 2Last Post: 10th Oct 2009, 16:57 -
how to increase/decrease and move a mask on a clip around(sony vegas)
By bojadada in forum EditingReplies: 4Last Post: 22nd Oct 2008, 22:38 -
From RGBA to mask avi
By fapo in forum Video ConversionReplies: 0Last Post: 2nd Jul 2008, 10:00
