Hi, I'm wondering is there a way to raise the volume in DVD's. One of the movies, which is in AVI format has a very low audio and I cant here nothing when I play it back in my DVD standoalone player. ANyways with any tutorials.
Results 1 to 12 of 12
if you are watching Avi(divx) on your dvd/divx player, load your avi into virtualdubmod and demultiplex the audio to wav and the video to avi.
open audacity load the wav into it and select an option there to raise the volume and then save it as mp3.
open virtualdubmod again and load the avi you demultiplexed before, click on streams and then stream list uou should see in avi here click on add on the right and add your raised audio.
click on the video tab and select direct stream copy
save your video
i think its this
hope it helps -
Alright, I'm going to try that. It seems like a long process though. On average how long does that take.
well done that for some dvd episodes i had and it took me 5 minutes for everything, i suspect 2 hour movie will be around 15 to 20 minutes
virtual dub doesnt encode anything , just demultiplex and multiplex the avi , what takes longer here is the audacity step
good luck -
Olá\Hi Cunha
i havent tried Sony Vegas, but to me normalizing the audio means comparing the high audio moments and the low moments and place the audio level in between.
he said he had a low volume avi so i think that wont help him much(but im not an expert)I love it when a plan comes together! -
like i said i never tried sony vegas,so im not aware of its possibilities.
the tools that i mentioned are both free, sony vegas and sound forge arent.
no need to buy top professional tools just because of one avi.I love it when a plan comes together! -
Ora pois pois...of course, my Portuguese friend - lol.....You're right fella...There are a lot of freeware that can do a great job.
So, if you already own SoundForge and Vegas, which of those two would you use? Offhand, I'd demux the file, normalize audio in SoundForge (where I have a ton of plug-in effects and filters) and remux. Is that too involved of a process? I've actually done it recently.
I would use both. Please note that Sound Forge is Vegas' default Audio editor. I guess this fact can answer lots of questions.
- This would be perfect, but you can choose. If you just want to normalize audio levels you can do that in Vegas (to raise volume). If you're having some clips, then I would use Sound Forge and its plug-in Clip removal. It's just the right thing to do.
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 17:06 -
dvd shrink low audio
By Xenon55 in forum DVD RippingReplies: 3Last Post: 17th Dec 2010, 22:01 -
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59 -
DVD Studio Pro -select Video, Audio and Subtitle track in low res for proof
By RonCole in forum MacReplies: 3Last Post: 3rd May 2010, 13:03 -
dvdfab platinum dvd to ipod audio low!!!
By Jorge in forum DVD RippingReplies: 7Last Post: 6th Sep 2007, 10:59
