I can't find a specific forum to post this to..this seems to be the closest topic relating to my question. I have a dvd9 iso..(not the dvd, just the image) and I was wondering if there is some way to compress that iso to fit on a dvd5? thanks in advance for the help..
Use DVDshrink, it will import ISO images and compress/reauthor as required.
Check out the guides section, and you will find plenty of assistance for using this program.
Also get yourself DVDdecrypter to burn the resulting output from shrink.
Good luck -
Use open image file (under file menu) in DVD Shrink to import the image, re-author, encode & shrink. Then use DVD Decrypter to burn the new ISO image.
Help: DVD9 ISO to what video container?
By helpanewbie in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2011, 11:00 -
How to create playable DVD9 onto bluray from .iso file
By WareISChris36 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jul 2011, 05:54 -
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
How do i convert an (ISO) dvd9 to a dvd5 and keep the menus???
By jcurrieirocz in forum Video ConversionReplies: 5Last Post: 26th May 2009, 08:15 -
DVD9 Iso to DVD5 question
By winman42 in forum DVD RippingReplies: 4Last Post: 13th Sep 2008, 14:12
