Results 1 to 20 of 20
    Nov 2003
    Cornwall
    Hi
    I have a dvd which has already been backed up by a friend but unfortunately there is a large countdown clock at the top of the screen. Is there anyway to remove this but still keep the quality of the film.
    Many thanx
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Is it intentionally a part of the original DVD ?
    If in doubt, Google it.
    use logoaway or logo subtitle remover.
    https://www.videohelp.com/edit#5;22
    and no you can' keep the quality. and this is not authoring. movin gyou.
    Nov 2003
    Cornwall
    Sorry Baldrick, what forum should this have been in
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sounds like someone has a prerelease copy of a movie.
    Google is your Friend
    Nov 2003
    Cornwall
    you obviously have the same! Did you remove the counter?
  7. Yes you can remove it.
    But it looks terrible
    Nov 2003
    Cornwall
    I will thanx
    May 2003
    He got a copy of ROTS and that's for sure.
  10. Virtualdub, with logoaway (and the right settings), then frameserve.
    It's virtually unnoticeable.
    Cheers, Jim
    My DVDLab Guides
  11. Originally Posted by reboot
    What are the settings?
  12. do these logo away programs just blank the area or do they attempt to fill it with the correct colours?
    i saw the screenshot of ROTS with those stupid counters on them here the other day
    i cant believe people could watch it with crap like that on the screen
    it didnt look awfully good picture quality either
  13. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    They try to fill it based on the background around it. Mostly you end up with a shimmery blur in it's place, which many people find more distracting
    Read my blog here.
  14. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I'd put myself in the more distracting boat. As far as WHAT he's backing up we don't know its Starwars so its it own business.
  15. I did 3 trials.
    First I used Region Remove. Horrible.
    Second I used MSU subtitle and logo remover. Better, but still bad.
    Third, I used Logoaway: thus:
    Cheers, Jim
    My DVDLab Guides
  16. Video Restorer lordsmurf's Avatar
    "Backed up" DVDs don't have "countdown clocks".
  17. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    exactly
  18. the counter clock is sometimes on the "extra scenes" of retail dvds
    think i saw them in the extras on
    1 season of alias not sure which off the top of my head
    national security
    shallow hal
    but no proper film would ever ship with them on
    can the logo removal be used on things like skyone programs or any other station which puts a stupid little signature on the screen
    or does it have to be box shaped which could end up screwing up more of the picture than if it was just left alone
  19. It can be used to remove (almost) anything from (almost) any video.
    It's limited only by what YOUR version of virtualdub/mod/mpeg/ac3 can open, with the codecs installed on your computer.
    I use it to remove TV station logos, hard codec avi subtitles, time counters, whatever...
    It's generally box shaped, however, using soft edges, varying the X Y weight, and the Blur power, you can almost always do better than leaving it on the screen.
    UGLARM does a better job sometimes, but is EXTREMELY slow...as in 10 times slower, so a frameserved encode to tmpgenc would take about 4 days
    BTW, it can also be used to ADD a logo or picture to the video.
    Cheers, Jim
    My DVDLab Guides
