I'm using Womble to edit my Pioneer DVD recorder captures of old 8mm and VHS video. I noticed that Womble will convert Linear PCM to Layer 2 and this reduces the file size quite a bit. I burned a couple of clips both ways and I really can't notice any difference.
Would there be a reason I shouldn't just convert all the clips I have? It would be great to cut down the file size, but what is the trade off or potential issues with this? Could this cause synch problems?
Thanks!![]()
If this material is original music and important to you, I would keep the PCM tracks. If not, do what sounds good enough to you.
How do you convert DTS to PCM
By ChrisDaMan in forum AudioReplies: 27Last Post: 29th Jan 2013, 02:32 -
How to convert PCM audio track inside M2TS file
By majouz in forum Software PlayingReplies: 1Last Post: 20th Jun 2011, 14:24 -
Possible to convert a 5.1CH 4608kbps PCM audio track to a 1536kbps 5.1 DTS?
By fluxcapacitormb in forum AudioReplies: 4Last Post: 20th May 2010, 14:46 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 12:08 -
duel layer to single layer question
By joelw_7 in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jan 2008, 01:25
