Is there any EASY way to compress .TS files into WMV-HD files? I saw some long procedure at AVSforum, but it was like gibberish to me, so if anyone here knows an easy way it would be much appreciated.
This might be a stupid question. I've used AutoGK to convert DVD to XVID. If I'm converting the .TS file to XVID, will I still be able to keep the AC3 sound if I choose to?
Also, do you have any suggestions on what would be a good compression rate for the files? Maybe is there like a certain size file per say hour or so to compress to? -
maybe
dgindex -> vfapi -> windows media encoder, https://www.videohelp.com/guides.php?guideid=759&howtoselect=6;34#759
or
dgindex -> avisynth -> WMNicEnc
are easier. -
Baldrick has it right, especially his recommendation of DGMpgDec-AviSynth-WMNicEnc
DGMpgDec -Demuxes the .TS into AC3 and M2v Files, creates .D2v file
AviSynth - Uses D2v file, resizes and filters source mpeg file
WMNicEnc - Encodes the AVISynth file to Windows Media
The above apps will give you a great looking final file. People are intimidated by AviSynth, but it is easy just to modify an existing script to work for you. AviSynth is probably the most powerful and cool video processing app out there. -
Though it doesn't handle all TS files it seems...
This one seems better: http://www.digital-digest.com/dvd/downloads/showsoftware_hdtvtompeg2_284.html
Convert wmv to mov
By formerpcgirl in forum ffmpegX general discussionReplies: 12Last Post: 21st Sep 2010, 16:38 -
What should I convert WMV to?
By videohalp in forum Video ConversionReplies: 3Last Post: 1st May 2009, 17:06 -
Cant convert to WMV
By batmax in forum Video ConversionReplies: 4Last Post: 11th Sep 2008, 02:17 -
Trying to Convert bluray to WMV
By MC Rodimus in forum Blu-ray RippingReplies: 5Last Post: 9th Jul 2008, 17:02 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16
