I've noticed that a lot of times whenever I get OGM files, especially those split into 2 parts, when I encode them to use on my Divx DVD player, the audio will get waaaaaaaaaaay off. On 2 parters it'll often get off on the second part but be fine on the first part, and others that are one part it'll just get off and stay off track from like a min or a few secs in. I once had this problem with episodes of a popular Anime that I watch, and I remember splitting the audio, running them through TMPGEnc with the uncompressed wav as the audio source, then compressing them to Divx with VDub, however this hasn't produced any real result with these, also VDub doesn't report that the audio is off like it does with straight AVIs with potential sync problems. Btw, these are dual audio OGMs with subs, and I take the OGMs and throw them into OGMDemux and then convert the audio to WAV then MP3 and reconcile them in AVIMux. It seems almost like the video is the problem, because the audio will almost always sync up with the subs perfectly, the video always either seems a few seconds one way or the other. Any help would be greatly appreciated, as I'm going crazy over this! I hate OGM and MKV![]()
Sounds similar to the problem many people have when combining 2 VCD's/SVCD's. You could try searching on that...could be a similar fix.
Google is your Friend
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 15:50 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 23:54 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 09:38 -
How do I convert .ogm file to .avi and keep a certain audio track?
By Moldiver in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 09:43
