I made a divx slideshow that I want to hand out to a bunch of people and I want it to autolaunch and play when inserted. What is a good free player that can run from the cd, in case someone doesn't have a clue how to play a divx file? I'm looking for something that doesn't need to be installed, but instead just runs when you insert the cd.
VLC (Video Lan) might be your best bet, I believe it has most codec (including divx) built into it.
You would need to set up the CD to auto run VLC, or have instructions for the person to open VLC, then the file. I have never done this, but I am sure it is possible. Do some searches for autorun cds or such.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Media Player Classic might be another app, as I *think* it uses its own inbuilt codecs.
See https://www.videohelp.com/forum/viewtopic.php?t=248279 for a description and samples of what I was able to do with MPEGs.If in doubt, Google it. -
Media Player Classic has some built in decoders, not anything to decode DivX though. Good thing is that it can load external filters without the need to register them. Never tried it with DivX though. XviD works fine, but it requires a registry entry before it decodes DivX.
Personally I would go with mplayer. Use a build compiled with cpu runtime detection and just have it open full screen. Insert CD, slideshow plays, player closes. No need for any interface. The users can just hit escape if they want to exit.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
So What Encoding Software Runs in Native 64-bit?
By Robert Simandl in forum Video ConversionReplies: 2Last Post: 29th Aug 2009, 10:13 -
Authored DVD runs on player but appears blank on Windows
By bluheat in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2008, 12:03 -
Any software player plays Divx with subtiltle
By newnews in forum Software PlayingReplies: 9Last Post: 1st Aug 2007, 09:38 -
Free Divx Software Player: Any Drawbacks?
By Tom Saurus in forum Software PlayingReplies: 0Last Post: 6th May 2007, 10:20
