"Gspot also allows you to check other features of your file. Many people tend to check the bitrate of a video file to check its quality, but the frame quality (Qf) is just as important - usually for a 1-CD (700mb) file it should be close to 0.20 bits/pixel, for a 2-CD file it should be close to 0.27. A new feature of GSpot is identification of B-VOP, Qpel and GMC. Note that if your file contains Qpel or GMC it is more than likely that an avi-compatible stand-alone dvd player will not be able to decode it."Originally Posted by thesnow
(Source: http://www.rita.lt/video_tools/help/gspot.htm )
Qf is a "Frame Quality" value in bits/pixel-frame.
Tool that gives more info about .mp4 than GSpot
By Wam7 in forum Newbie / General discussionsReplies: 15Last Post: 7th Nov 2019, 05:51 -
wmp win7 not playing certain mpeg1 files, gspot info included
By Rudyard in forum Software PlayingReplies: 6Last Post: 7th Jan 2011, 03:53 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
GSpot media info accuracy?
By ecc in forum Video ConversionReplies: 4Last Post: 7th Feb 2008, 09:27 -
Help with Gspot Results
By Dawter in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2007, 08:01
