Hi every expert out there.
I bought my first standalone DVD-player 2 weeks ago.
The main reason I bought it was to view my edited analogue camcorder videos at my TV-set (PAL).
I've always had a great interest in video editing, and I thought this was great, using SVCD for Master instead of magnetic tape!!!
I'm more concerned about the Video Quality then audio.
There are MILLIONS of of chances to make a wrong setup...
I really need some advice...
I would like some comments about my "workflow/setup" and answers to my questions, please.
The setup should be optimized for TV (PAL).
This is the workflow I've been using this far:
Software:
--VirtualDUB (capture, clip, filter, frameserver)
--TMPGEnc
--Nero 5.5
--VCDeasy (create "chapters" and burn)
Capture (VirtualDub):
--CanonUC5 Hi8 (PAL) camcorder connected to capturecard(soundcard) via S-video(Line)
--VirtualDub, size 704x576 with Codec Huffyuv or PivVideo Mjpeg.
--At this point, I'm only adjusting Brightness/contrast while viewing histogram.
Edit/filter/frameserving (VirtualDub):
--Filtering. Need some advice here...
--Start frameserving
Encoding (TMPGEnc, Really need advice here!!!)
--Video/audio source Frameserver(virtualDub)
--So far I've been using Leons SVCD template.
--Video Tab
Stream type: MPEG-2
Frame Rate: 25 fps (25/1=25)
Rate control: Auto VBR (Q=70, max=2450, min=300, Padding enabled)
VBV 112 kb
Profile: MP@ML
Video format: PAL
Encode Mode: Interlace
YUV: 4:2:0
DC prec: 10 bits
Motion search prec: High quality
--Advanced Tab
Video Source: Interlace
Field order: Top field(A) first
4:3 625 line (PAL)
Video arrange: Full screen
--GOP tab (Have no Idea what this is for)
--Quantize tab (Have no Idea what this is for)
--Audio Tab
Stream Type: MPEG-1 Layer II
Sampl freq: 44100
CH. mode: Stereo
Bitrate: 128 (to prior filesize and Video quality)
--System Tab
Stream Type: MPEG-2 Super VideoCD (VBR)
Questions:
--Does my Camcorder produce video good enough to "make it worth" capturing in 704x576 for SVCD?
--Does Hi8 producing video with quality=VCD? If so, should I capture 704x576 anyway, to produce better VCD's?
--Is my Canon camcorder producing interlaced video or not?
--If interlaced, WHEN should I deinterlace my video? During capture (virtualdub)? During encoding (TMPGEnc)? Or both?
--Or is the deinterlace filter just for filtering? An interlaced source is still interlaced even after filtering?
--When using VirtualDub as a frameserver, where should I setup filters? In VirtualDub or TMPGEnc?
--TMPGEnc settings:
Adv.Tab. Video Source Type = Interlaced or Progressiv?
What about using an deinterlace filter?
Does this make source progressiv for an interlaced movie?
--SVCD size should be 480x576. Does cropping affect my video quality? It's not 4:3 anyway...
--Ho do I avoid Blocks in high motion scenes?
Peter Östlund
Results 1 to 1 of 1
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 02:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26 -
Hi8 to Digital
By 9ura in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 03:56 -
Improving Hi8 Look
By rvalich in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 18:43
