I am using PowerProducer 2 Gold in order to create a DVD
1. I have created a big number of *.ppp files and I want to add them to
make a movie. Is it possible to open several ppp files? Everytime I open
one the other closes, so I guess that it is impossible...
2. To overcome it I burned to the hard disc those ppp files as dvd files and
then i imported them as VOB files and combined them to different scenes.
3. Then I opened the combined files in order to add one to the other and complete the movie and Power Producer 2 Gold refuses to burn
them... it gets stuck at some point of the burning process.
4. I then cancel burning and get Error number 10003 or so - but it says
aborted process - that is to say - the error is that I cancelled the process.
5. What am I doing wrong?
1) Have you burned a dvd with this software before?
2) Did you upgrade the software via the Cyberlink web site? -
The .ppp files are Power Producer 2 Gold's project files and the program can only have one project open at a time.
When you capture video it is stored after transcoding is completed, in the ppwork folder as a .mpg 2 file, and you can add as many of those to a project as will fit on a DVD (either 4.7g or 8.5g with the latest patch) and create a DVD that way.
You can merge all the video files or create separate chapters for each clip.
PP 2 Gold has a pretty thin DVD authoring setup, so I capture video with it to get the .mpg 2 video and then use TMPGEnc DVD Author 1.6 to create the DVD.
The latest program patch fro the Cyberlink site lets PP2 Gold burn and author 8.5g DL DVDs.
Audio Codec Not Working in PowerProducer
By travbickle in forum Software PlayingReplies: 21Last Post: 5th Dec 2011, 14:28 -
DVD+R Gold vs. "Gold"?
By buddycat in forum MediaReplies: 15Last Post: 21st May 2010, 07:22 -
PowerProducer - edit dvd menu template
By kj1983 in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2008, 19:37 -
Alternatives to PowerProducer?
By Nilfennasion in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jul 2007, 11:32 -
Using Cyberlink PowerProducer... no video during authoring
By 27am_dot_com in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 20:55
